Learn how to fasten and air-seal rigid-foam sheathing
to the outside of an existing house
with David Joyce
VIDEO TRANSCRIPT:
David Joyce: We’ve stripped the house of all the siding, we’ve put on the housewrap, and now we’re applying the two 2-inch layers of polyisocyanurate.
MORE VIDEOS IN THIS SERIES
Insulation Retrofit Complete
2. Strip Siding and Roofing (free)
3. Install Housewrap and Roof Underlayment
4. Install Rigid-Foam Over the Walls
5. Install Rigid-Foam on the Roof
6. Flash Windows Over Rigid Foam
7. Choosing Details and Materials (free)
RELATED CONTENT
Remodel Project: Deep Energy Retrofit
Podcast: What Is a Deep Energy Retrofit?
The History of the Chainsaw Retrofit
Roofing and Siding Jobs Are Energy-Retrofit Opportunities
Narrator: Using multiple layers of foam rather than a single layer of thick foam helps you get a better air seal, because you can offset the seams on both edges of the sheets. Start with a 2-foot rip at the bottom of the wall and stack a full sheet on top of it. The next layer will begin with a full sheet. Take a little time to square up the first sheet so that the corners are good and plumb. This way, you won’t have to cut all the factory edges from the subsequent sheets. There are a lot of obstructions on the outside of a house—spigots, electrical conduit, meters. Some can be worked around; some need to be moved. If a spigot is too short to absorb an extra 4 inches of wall thickness, cut it off and replace it later. Dave likes to use roofing buttons to hold the foam to the walls. In this video, his crew uses spikes and screws interchangeably. Now they use screws exclusively. Screws are easier to remove, if needed. Screws are also easier to adjust. One of…
Informative, but how do you
Informative, but how do you treat the windows?
Response to Paul J. Boniface
Paul,
Here are some links to help you:
Window Installation Tips for a Deep Energy Retrofit
Extending Window Openings for a Deep Energy Retrofit
Nailing Window Flanges Through Foam
‘Innie’ Windows or ‘Outie’ Windows?
Thanks for this - Very
Thanks for this - Very helpful.
