What type of insulation should I use in my walkout basement with cinder block walls?
Deaddeer | Posted in Energy Efficiency and Durability on
Most of the walkout is above grade, I’m not sure if all the walls are cinder block or if there is some concrete.
  1. GBA Editor
    Martin Holladay | | #1
    Eric,
    These walls should be insulated just like the walls of a basement that is below grade. This article tells you what you need to know: How to Insulate a Basement Wall.
