Using used (recycled) rigid insulation
hey guys, thank you in advance to any that answer or help with my questions.
i recently bought some used 4″ Dow Roofmate rigid insulation from a roofing contractor. i plan on using it on my crawl space foundation walls. one side of the insulation is a bit distressed and by distressed i mean it has cuts, slices and dents. will this affect the performance of the insulation? should i face the distressed side against the wall or the good side against the wall? would it help at all to paint the distressed side with a latex paint? any thoughts would be appreciated. thank you
The dents and scrapes will not significantly affect the performance of the insulation. You can face the dents either way.
Note that most building codes require rigid foam in a crawl space to be protected by an ignition barrier or a thermal barrier (usually drywall).
For more information on attaching rigid foam to concrete walls, see these two articles:
Building an Unvented Crawl Space
How to Insulate a Basement Wall
-- Martin Holladay
