“Protective covering” for exterior foam?
![](https://secure.gravatar.com/avatar/103b7cf297000837ac637692890bf151?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
Hello:
The attached detail suggests a protective covering that covers the exterior insulation at a basement foundation wall. What is a commonly used “protective covering” for this detail? Given the proximity to the ground and code requirements for clearance to exterior cladding, I’m stumped as to what to use here?
Thanks!
Stephen,
I implemented this detail, except in a retrofit situation, and I had painted aluminum trim coil custom bent for the application. Another idea I have heard was to use tile backer board.
Stephen,
This topic was covered in a previous article ... see the following link:
https://www.greenbuildingadvisor.com/blogs/dept/qa-spotlight/how-finish-exterior-foundation-insulation
Stephen,
The answer to your question can be found here: How to Insulate a Basement Wall.
The above-grade portions of all types of exterior insulation must be protected from physical abuse and sunlight. Among the products than can be used for this purpose are the following:
A cementitious coating or cementitious stucco (for example, Styro Industries Brush On ST), with or without metal lath
A cementitious coating that includes chopped fiberglass (for example, Quikrete #1219 foam coating or surface-bonding cement)
An acrylic coating like Styro Industries FlexCoat or Styro Industries Tuff II
EIFS (synthetic stucco)
Cement backerboard, with or without a layer of stucco
Pressure-treated plywood
Metal flashing
A fiberglass panel like Ground Breaker from Nudo Products
Styro Industries FP Ultra Lite panels (XPS coated with mineral granules adhered to one side)
Protecto Wrap Protecto Bond (a flexible peel-and-stick membrane with a textured, gritty coating)
ProGuard Cement Faced Insulated Sheathing.
For more information on this topic, see How to Finish Exterior Foundation Insulation.
Thanks guys, I think the simplest solution might be the pre-finished aluminum. I should have (but didn't) clarify, that this is for a new 'spec' home at the lower end of the market for a developer/builder who is looking to clutch the purse-strings as tightly as possible.
Thanks!
