My basement walls sweat at the above ground area.
![](https://secure.gravatar.com/avatar/899758653f9ceea586115cdc3b2f5176?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fw.png&r=g)
We heat the space and use as living space. Would insulating this area help with this problem. I was also wonder if I would have to use a 2×4 wall or could I use something like a 2×2.
William,
You are getting condensation on the wall because the wall is cold. Yes, insulating the wall will help. Here is a link to an article that will explain everything you need to know: How to Insulate a Basement Wall.
