Has anyone used EcoFoil or radiant barrier/insulation in basement?
We are trying to protect our concrete basement from moisture. We were thinking about putting EPS foam on the floors and walls as a thermal and vapor barrier. We still may go that direction, but I am concerned about our daughter’s chemical sensitivities and the flame retardants in the foam. Has anyone used a radiant barrier like EcoFoil on the walls and concrete slab (under laminate)? Here is a link to the product: http://www.ecofoil.com/All-Products/Concrete-Insulation. We plan to insulate the walls with mineral wool batts on top of the foam or foil, so I am not too concerned about it’s insulative value. Thank you!
Caroline,
If you don't care about the product's insulative value, why do you want to install it?
If you did care, you might be interested to know that a radiant barrier is useless unless it faces an air space. So if you sandwich it between concrete and a mineral wool batt, it won't help insulate. But evidently you don't care about that.
If you simply want a vapor barrier, it would work. But there would still be problems using an air-permeable insulation like mineral wool in the interior side of this type of vapor barrier -- because the vapor barrier would be cold. That means that you will get condensation on the vapor barrier.
Here is a link to an article with more information on these issues: How to Insulate a Basement Wall.
