Can moisture-resistant drywall, if sealed properly, be used as a vapor barrier?
![](https://secure.gravatar.com/avatar/5597f3eb72af1cdd98f59a622d6bbbc9?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
519woodfrog
They are basement walls and were sealed before framing and have Roxul rigid board behind the studs as a thermal break.
Chris,
There are really two questions here. The first question concerns whether drywall is a vapor barrier. The second question concerns the best way to insulate the interior of a basement wall.
1. No, drywall is not a vapor barrier. Drywall is vapor-permeable. However, there is no need for most walls to have a vapor barrier. Some building codes require above-grade walls to have an interior vapor retarder -- which is a lesser standard than a vapor barrier. To meet this requirement, you can install a layer of vapor-retarder paint on the drywall.
2. I don't recommend the use of Roxul mineral wool insulation to insulate basement walls on the interior. For advice on the right way to insulate a basement wall, see How to Insulate a Basement Wall.
