Best way to insulate
![](https://secure.gravatar.com/avatar/93deddb534449863caf285c11a946c67?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
In climate 6, what is the best way to insulate and not have water issues? insulating in the cold traps moisture, how to eliminate this problem. I have heard that blowing in wet cellulose into wall cavities can trap moisture and rott sheeting and wall studs. Not sure if it is in my budget to use closed cell spray foam. Any suggestions
Mark,
It sounds like you are just beginning to think about insulation issues. The first place to start to learn about these issues is the GBA Encyclopedia. I recommend these articles:
Insulation Overview
Insulating Roofs, Walls, and Floors
Insulation Choices
Batt and Blanket Insulation
Blown-In or Loose-Fill Insulation
Rigid Foam Insulation
Spray Foam Insulation
<a
