Detail Library
Building Plans for Energy Efficient Basement Remodeling
How to Finish a Basement for Energy Efficiency and Comfort: Details for a basement that insulates against water, weather, and radon gas.
These detail drawings are available to GBA PRO members. BECOME A MEMBER AND GET FULL ACCESS TO GREEN BUILDING ADVISOR
RADON/WATER MANAGEMENT
Sub-Slab Radon RetrofitDOWNLOAD: PDF | DWG
Wall Section w/ Interior Drain & SumpDOWNLOAD: PDF | DWG
Interior Footing Drain, Insulated SlabDOWNLOAD: PDF | DWG
Interior Footing Drain, Rubble WallDOWNLOAD: PDF | DWG
FREE SAMPLE:
Underground Water Barrier RetrofitDOWNLOAD: PDF | DWG
BAND JOIST
Rigid Foam RetrofitDOWNLOAD: PDF | DWG
Spray Foam RetrofitDOWNLOAD: PDF | DWG
FRAMED INTERIOR WALL – METAL STUDS
1-5/8 in. Stud, Rigid Foam (2-in.)DOWNLOAD: PDF | DWG
1-5/8 in. Stud, Spray Foam (~3 in.)DOWNLOAD: PDF | DWG
FRAMED INTERIOR WALL – WOOD STUDS
1×3 Stud, Rigid Foam (2-in.)DOWNLOAD: PDF | DWG
2×4 Stud, Spray FoamDOWNLOAD: PDF | DWG
2×4 Stud, Rigid Foam (1-in.)DOWNLOAD: PDF | DWG
2×4 Stud, Rigid Foam (2-in.)DOWNLOAD: PDF | DWG
2×4 Stud (Flat), Rigid Foam (2-in.)DOWNLOAD: PDF | DWG
INSULATED SLAB FLOOR
2×4 (PT) Sleepers, 1-1/2 in. Rigid FoamDOWNLOAD: PDF | DWG
2×4 (PT) Sleepers, 3 in. Rigid FoamDOWNLOAD: PDF | DWG
Mechanically Fastened SubfloorDOWNLOAD: PDF | DWG
Detail Packages that can make old houses energy efficient:
  • Detail Library
    Building Plans for Energy-Efficient and Healthful Kitchens and Bathrooms
    ###How to Remodel Kitchens or Bathrooms: details that will help you stop air leaks and insulate exterior walls behind tubs and showers, seal penetrations in the ceiling from recessed lights,…
  • Detail Library
    Building Details for a Deep-Energy Retrofit
    How to upgrade windows, walls, roofs, and basements with spray foam, rigid foam, blown-in cellulose, and other insulation types 11 Detail drawings in this Deep-Energy Retrofit collection: ROOF INSULATION RETROFIT…
  • Detail Library
    Building Plans for Advanced Framing
    How to Add Energy Efficiency to Rough Framing: Reduce thermal bridging with less lumber and more insulation — energy efficiency and comfort are bonuses ADVANCED FRAMING DETAILS IN THIS PACKAGE:…
  • Detail Library
    Building Plans for Insulated and Conditioned Crawlspaces
    How to Seal A Crawlspace from Air and Water Leaks: Construction Details For a Mold-free, Energy-Efficient Crawlspace. 23 Encapsulated crawlspace details for a tighter, more energy-efficient , healthier, and more…
