Jeepasaurus, a GBA reader from Eau Claire, Wisconsin, recently bought a log house sitting atop a permanent wood foundation (PWF). Although initially reluctant to buy the house because of this detail, Jeep did enough research to convince him there’s nothing inherently wrong with a wood foundation. The problem is how to insulate it.
In a Q&A post, Jeep explains that he has gutted the basement to the 2×6 studs, removing the wood paneling and the underlying gypsum drywall that had covered the walls. The previous owner had installed a vapor barrier behind the drywall and insulated the stud cavities with fiberglass batts. The insulation was damp in a few spots near the bottom of the wall, but there was no sign of mold.
The basement is generally dry. The only time Jeep has seen evidence of water there was after an early spring rainstorm when the ground was still frozen. In that instance, some water seeped through the wood sheathing covering the outside of the foundation wall. The plan is to turn the basement into two bedrooms for his children, and for that reason Jeep wants the space to be well insulated and comfortable.
Spray foam insulation is too expensive. Jeep has gone through Joe Lstiburek’s book on building in a cold climate and noted the recommendation that the foundation wall be insulated on the exterior with rigid insulation.
“I like the idea of the rigid insulation on the exterior,” Jeep writes, “but I’m curious if I would have to install it all the way down to the footing, or if it could be installed from the top plate to 16-18 inches below grade? Then on top of that … how could I make the transition from the logs to the rigid insulation as the rigid insulation…
Egress ?
Is there the proper egress for two "legal" bedrooms? Include this in your plans.
WeatIfher Sealing
I have designed/built a few score pwf's over the past few decades. They are our preferred option due to fewer basement problems, lower embodied energy, ease and lower cost of insulating with non-foam products, reduced thermal break issues, fewer trades and ease of scheduling, easier finishing,.... Why would we consider concrete? But of course proper water proofing strategies are integral. The walls are placed on a minimum of 5" of clean crush. A sump is required by code. Exterior ply wall joints are caulked with butyl, 2 coats of water based foundation coating are applied and a dimpled foundation mat with exterior geotextile covers the wall. The pwf walls under consideration here should be excavated and assure proper water proofing treatment is applied. The sandy soil indicated as well draining is suspicious since there appears to in fact be water present (otherwise the ground would not have been frozen in the spring as indicated). If the walls are excavated and the soil at the bottom is not well draining (no gravel strip below fdn.plate) replace a few inches below and to the side of the bottom plates with clean gravel. Cover the gravel with some landscape fabric before backfilling. Use a good interior air barrier with variable vapour permeability such as Membrain. You will have a warm, dry home with a basement far outperforming the logs above.
In my experience achieving high energy performance with more responsible materials can be met at lower cost to the project and the environment with pwf's. I live and work in Alberta.
