Brick veneer inward vapor diffusion with exterior mineral wool
![](https://secure.gravatar.com/avatar/81782360bde7fa3fd599e8a84f0e1706?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
Heard some opinions that mineral wool will slow down inward brick veneer vapor diffusion causing build up of moisture in the cavity. This was the planned exterior wall.
Brick veneer – 1″ space – 1.5″ mineral wool – 38 perm rated wrb (mento 3000) – 1\2″ cdx – 2×6 with mineral wool – intello vapor retarder.
Was thinking to forgo the exterior insulation altogether and have a bigger drying cavity between the brick and wrb. Any recommendations?
