Zip R bottom detail
![](https://secure.gravatar.com/avatar/e7d5c9797e8636341886688a648bfa01?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fs.png&r=g)
I remember seeing a sealing detail for ZIP R panels at the panel to foundation intersection. The detail had a piece of treated lumber pinned to the foundation below the panel then the the seam was taped or liquid flashed. I cant seem to find it again. Can someone point me in the right direction?
Seems fussy. Our preference is to keep the sheathing in the same plane as the foundation. There's a good photo here: https://www.buildingscience.com/documents/building-science-insights-newsletters/bsi-096-hot-and-wet-dry
John,
I agree. The detail only become necessary because they didn't adjust the plane of the framing to compensate for the Zip sheathing.
I am checking with tech contacts at Huber for this detail. I think termination of the bottom course of any sheathing--in terms of flashing and sealing--is a detail often not treated with the import it has to taking all the water load and terminating its management right at the bottom edge.
There are a number of wall termination details here (http://www.huberwood.com/assets/user/library/R-Sheathing_Jobsite_Poster.pdf) but I don't think they comprehensively deal with water and air control layer continuity.
More soon - Peter
The link below will take you to Huber technical library web page with a list of installation details for typical transitions, terminations, and penetrations on ZIP-R panels. I would recommend to check details #1 and #11, cause they probably address your question the best. My favorites in both of these details are Scenario 2 which both give you a little overhang of ZIP sheathing only over the slab edge, which can easily be treated either with tape or liquid flash. It is probably better idea to use a liquid flash over concrete, and protect it from exposure to sun and UV by adjusting the height of base flashing that comes over it. This approach will also eliminate a pathway for pests to chew through the foam, although you will pay the price by loosing few inches of interior space by setting the ZIP-R panel this way.
Hope this helps.
Link: http://www.huberwood.com/technical-library/48/355/360
P.S. Peter, thanks for chiming in on this one.
Spenceday, I believe the you were watching an NS Builders video--about 5 minutes in:
https://www.youtube.com/watch?v=MGk2i4QiU-8
Great detail!
Thanks for the replies! No doubt I saw it on that NS builders video while only half watching and filed it away in my head then forgot where it came from.
I did look at the Huber literature before posting here. I’ll probably use metal flashing in conjunction with liquid flash as the detail.
Spenceday, I came across the "better" NS building video on the Zip R detail. At about the 8:15 minute:
https://www.youtube.com/watch?v=IFdxRNsdcZ0
