XPS foam board on the interior side of kraft-faced fiberglass
![](https://secure.gravatar.com/avatar/01f73ccb3664fd3e97de891b83fe9a24?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fb.png&r=g)
I live in southern Maine, zone 6 and I have a 95 year old bungalow that we just built a 12 x12 dormer on. The plan was to use cathedral r30 unfaced fiberglass followed by 1/2 inch XPS and then strapping and drywall.
I came home to my builder using faced r30 (which was put on AFTER he strapped the ceiling) and running the xps in strips in between the strapping…
Obviously a miscommunication. My question is, will the two vapor retarders cause problems?
Thanks,
Bob
Bobby,
No, these two adjacent vapor retarders won't cause any problems.
The main problem with this roof assembly is its low R-value. In your climate zone, you should really be aiming for R-49. Most of the R-value of your roof assembly comes from the R-30 fiberglass, and the performance of that insulation is reduced by thermal bridging through the rafters. And 1/2-inch rigid foam has a very low R-value -- about R-2.5. Finally, the performance of the rigid foam has been greatly compromised by cutting it into thin strips and inserting it between the strapping.
Unless it has vapor retardent facers1/2" XPS isn't even a Class-II vapor retarder- it's only slightly more vapor tight than latex ceiling paint.
If the R30 has a foil facer (unlikely) that would be a Class-I vapor retarder, limiting what you can do later. If it's a kraft facer, it's a "smart" vapor retarder, usually about 0.5 perms when dry, but 5 perms or higher when the humidity in the fiberglass is high.
