x flat tie
![](https://secure.gravatar.com/avatar/a1514a5bdacc51e8e71bcf0cb58eccea?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Our concrete crew uses x-flat ties for concrete forms.
Do these ties contribute to thermal bridging?
If they do how do we mitigate this problem?
Jeff
Concrete conducts heat so readily that a bit of steel does not make a noticeable difference. Foundation walls should have continuous insulation on either the interior or exterior. Building codes allow uninsulated foundation walls if the first floor framing is insulated but that's not a good approach from a building science viewpoint.
Thank you
