Would extremely cold temperatures in the cabinet under an induction cook top cause an intermittent buzzing sound?
![](https://secure.gravatar.com/avatar/7ac897c15b4d4aa72f50541c249d08d6?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
Would extremely cold temperatures in the cabinet under an induction cook top cause an intermittent buzzing sound in the early mornings? If so, what is probably happening? We don’t hear it later in the day. Outdoor temperature was 7-10 degrees.
The induction cook top is about 10 years old. As far as we know, it has not done this before.
I'm sure you've read that induction cook tops have a tendency to buzz when used with certain types of cookware. But it sounds like your unit starts to sing even when turned off, correct? Have you owned this appliance for some time? Has it always buzzed whenever the outdoor temperature is cold? Is the floor area underneath this particular cabinet not insulated?
Thanks, Steve, for your reply. We've had the induction cook top for about 10 years but don't remember it ever "singing" when it wasn't turned on. Our brick house was built in 1843; the kitchen was added at some point. It is not insulated nor is the basement under it so it gets very cold during the winter nights. Last night I kept the cabinet doors open and we did not hear the "singing" this morning. I was worried yesterday that the motherboard was failing but also wondered if the very cold temperatures we had for two days was causing something in it to reset continually.
Most people understand water and electricity do not play well together. If the cook top gets below the dew point in your home it could get wet and is likely self-destruct. If the air in your home is 72° with 55% RH the dew point will be 55°.
If it is that cold in your kitchen the real fix will to block the air flow and insulate as needed.
You may want to read FAQ #9 on this web site.
http://theinductionsite.com/faqs.php
Mary Ann. There are many reasons to consider reducing air infiltration and improving insulation values even if those actions don't resolve your cook top problem. This site offers a wealth of knowledge on how to retrofit older homes.
