Wood Trim Around Windows-Waterproofing
![](https://secure.gravatar.com/avatar/7ce45b6b3336621a00962cd1ea250564?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ff.png&r=g)
I’m having to replace this wood trim and found this-The wood trim was installed over some 1-1/2″ fillers between stucco and window frame. The building paper is intact under the nailing flanges. I broke stucco back to reflash the fins, and will add additional paper and lath. But my question how to add a sill and re-trim around the windows. I hate to change the “frame style” trim because it’s on the rest of the windows. But, I may have to fix those too anyway! Also, I’ll need to patch the stucco up to some point around the window. Open to any and all suggestions. Thank You.
I haven't worked on stucco buildings but I don't understand why you can't use the same type of trim.
