Wood on the inside of exterior walls.
![](https://secure.gravatar.com/avatar/cedcfec56f2132fdc3b5e4a6493ccb36?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
If I plan to install shiplap on interior side of exterior walls and ceilings should I install a “smart” membrane on the studs prior to the shiplap or would I be better off with drywall behind to control air movement?
In most climates, you would be even better off with OSB - to serve as a durable air barrier and somewhat smart vapor retarder.
A vapor retarder membrane is more susceptible to damage than drywall is, but otherwise either will work. You can use anything that will act as an air barrier, so a vapor retarder, drywall, plywood, etc. You need an air barrier because shiplap is like a tongue and groove ceiling with all the little gaps that leak. Just don't use something that is a full vapor barrier (like polyethylene sheet) here.
