Window installed with no sill pan
Fetch | Posted in General Questions on
Do I need to remove window and install sill pan or flashing?
I removed trim around my windows to find water saturated OSB and also found that the windows were installed with no sill pan or flashing.
    Michael Maines | | #1
    Sill pans have only been in regular use for 20 years or so, and still not ubiquitous. They are best practice, though, and since you are seeing signs of water infiltration, you can either retrofit pans and proper flashing now, or at a later time when the damage will be greater.
