Window in brick / stucco reinstallation?
ggeoff | Posted in General Questions on
Hello,
I’m doing some work on a pre-existing extension here in New York and I found a serious draft coming from the window.
When I pulled the trim I found a lot of wood rot and no insulation or flashing. I also noticed the wooden buck extends through the wall and is flush with the exterior stucco wall.
I’ve never seen a window installed like this, from what I know it looks sloppy but don’t have a lot of stucco experience.
So, should I be pulling this all out and reinstalling or can this be salvaged somehow?
-G
    Akos | | #1
    I'm not a stucco guy, but that does not look like a proper install. There should have been a head flashing on the top of the window at least.
    A google result of proper install:
    https://ppc.ucsc.edu/consultants/images/appendix-h---standard-plaster-installation-and-details---standard.pdf
    Fixing it will not be simple.
