Will pocket door gaps at jamb allow avoiding a transfer duct?
![](https://secure.gravatar.com/avatar/9e767f0331b2357493601403b5dc75c4?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
Hi there: I’m trying to calculate undercuts necessary for balancing an HVAC system in a couple new residences. But then it occurred to me, that since all the doors are pocket doors, and since the Johnson Hardware we’re using specifies a 3/16″ gap between the jambs and the door panel on either side of the door, that this gap could be considered a “transfer grille” of sorts… The smallest 30×80″ door would therefore have the equivalent of 20in2, not including any undercut.
Am I thinking about this in the right way? Do these 3/16″ gaps give me what I’m assuming they do, in terms of airflow?
thanks!
I looked at my pocket doors ( with Johnson hardware) and I don't think you'll get much airflow around the doors when closed. The only unimpeded path is underneath.
