Will a ‘flat roof’ vent properly and will condensation be a problem without outboard rigid?
james@studio-e | Posted in Energy Efficiency and Durability on
I’m having a debate with the contractor and roofer over a roof assembly with a height limit and would appreciate input.
The assembly from inside to out is gyp, vapor barrier, 9 1/2″ TJI with blown-in cellulose and 2″ of rigid held under the top member, 5/8″ sheathing, TPO. With a 1 3/8″ top member, this provides us with a 1 3/8″ air channel. We can even increase this to 1 7/8″ by setting rigid off with 1/2″ strips along the top members.
Neither the contractor or roofer think this will vent properly and think condensation will be a problem. The roofer wants a minimum of 1/2″ rigid on-top of the sheathing and is more comfortable with 1″ to allow for staggering joints with (2) 1/2″ layers. We see this as a waste as the air above and below the sheathing is outdoor air.
Then there is the debate whether or not the roof should be designed as a vented or unvented roof.
The trick here is that the roof assembly has to both cost effective and within a maximum thickness due to height constraints for an ADU.
Thanks for your comments!
  1. GBA Editor
    You wrote, "Neither the contractor nor roofer think this will vent properly and think condensation will be a problem."
    Your contractor and roofer are right. This is a bad assembly.
    You have two choices:
    (1) You can create a vented assembly, which will require a vented air space above the top of the insulation that is at least 6 inches high. The roof assembly will also need to meet the other criteria outlined in this article: Insulating Low-Slope Residential Roofs.
    (2) You can create an unvented assembly, which will require a thick layer of rigid foam above the roof sheathing. (Exactly how thick depends on your climate zone.) Again, all the information you need can be found in Insulating Low-Slope Residential Roofs.
    -- Martin Holladay
