Whole house ventilation
![](https://secure.gravatar.com/avatar/fdb0d46ebf9a0726f07e15275d474ab7?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ff.png&r=g)
Good Morning experts.
Need your help to understand the code on whole house mechanical ventilation for New York State.
From what I gathered one could use bathroom fans as vehicle for exhaust and whole house ventilation as spelled in M15054.4 per NY state residential code.
From the code below, I read it as it is not mandatory to have fresh supply air.
The whole-house ventilation system shall consist of one or more supply or exhaust fans, or a combination of such, and associated ducts and controls. Local exhaust or supply fans are permitted to serve as such a system. Outdoor air ducts connected to the return side of an air handler shall be considered as providing supply ventilation.
https://up.codes/viewer/new_york/irc-2018/chapter/15/exhaust-systems#M1505.4.3
The question I have is, does this kind of system need make-up air. Engineer says the source is leaks into the building from construction.
Thank you.
