Who is the manufacturer of the perforated L flashing widely available in the BC area as mentioned in an earlier post?
LonomPraaw | Posted in Green Building Techniques on
A gentleman by the name of Malcom Taylor answered to the question on May 15, 2012 and referred to this product.
    MALCOLM TAYLOR | | #1
    Hi Ed,
    I'll call my lumber yard tomorrow to see which one they stock. i suspect it is from Dynamic Metal Solutions in Surrey BC. NorthClad in Everett, Wash. also makes one.
    If you have a ten ft. break you could probably save a bit by bending them yourself from strips of perforated alum. soffit material.
    MALCOLM TAYLOR | | #2
    Ed,
    Slegg lumber makes their own. They stock 1/2", 3/4" and will custom make any other size to fit the cavity and siding used.
  3. LonomPraaw | | #3
    Thanks Malcom. After some research of products in the area, I found soffit with holes the desirable size and went ahead and bent them myself. I appreciate your input.
  4. Expert Member
    MALCOLM TAYLOR | | #4
    Cheers!
