Where to use Polyiso Rigid Foam Insulation Board
![](https://secure.gravatar.com/avatar/00652d49068e10ad71a9582b97e9f498?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
I just bought a home made of all cinder block. The previous owners covered the exterior of the house with Polyiso Rigid Foam Insulation Board and then cedar siding on top of that which i would like to remove and replace with stucco. Should i keep the insulation on the exterior of the house and stucco over it or should I remove the foam and stucco directly over the block?
In addition, I found a stack of about 20 – 2″sheets of the Polyiso foam board in my attic. Can i use these to insulate my basement or should I be using a XPS foam board?
Thanks for your help.
