Where to exhaust condition crawl space
I live in SW Colorado, climate zone 5. I have an approximately 600 sq ft crawl space, which is adjacent to a basement/garage, which is outside of the house’s envelope. I am in the process of changing the crawl space from a vented to conditioned, bringing it inside the house’s envelope.
My question is, since I need to air exchange in the crawl space, I was planning on having a low powered fan to depressurize it. Can I exhaust the fan into the basement(outside the envelope) or does it need to exhaust into the house(inside the envelope?) Any recommendations on a fan that can do 20CFM or so?
Thanks
Chris
Have you tested for radon? The result may inform your next step.
Chris,
How are you conditioning the space? Where would the make-up air for the crawlspace come from?
The options are in the IRC, section R408.3: https://codes.iccsafe.org/content/IRC2018P4/chapter-4-foundations#IRC2018P4_Ch04_SecR408.3
I have tried or been otherwise involved with all of these approaches. With what I know now, I would opt for a dehumidifier and a heat source. Anything else either wastes energy or is hard to get tuned correctly.
I have an ongoing radon testing device, and it reports consistently <0.5 picocurie. I will also be venting "soil gas" to the outside with a sub-vapor barrier pipe, that isn't powered but could be.
As far as make up air, that is the question about vents. Since the subfloor, to the living space above, isn't air sealed, is that good enough or so I need to cut in a register?
Thankfully I don't need a dehumidifier, as the soil is dry and I live in the high desert.
What kind of heat source would be the best?
