Where to buy EPS foam (25 psi, termite-treated) for use under a concrete slab in West Virginia?
![](https://secure.gravatar.com/avatar/52f9a11b8081e80b8051007e72842c18?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
If someone could assist me it would be much appreciated. I have spent several days calling and searching the net. I am building a house with a large basement using superior walls. I want to insulate under the slab with 2 inches of eps foam but I cannot find anyone near that sells it. I want eps not xps. The house is being built near Charleston wv. I would not care to drive 1-2 hours to pick it up, but would like to find a company that could deliver it to the construction site. Closest I could find was a 6 hr drive and they would not deliver. Thanks for any help.
By the way I was amazed no one in my area seems to know anything about insulating under slabs…?
I finally found one guy who did.
Chris,
The only method for treating EPS to resist termites (as far as I know) is the PerformGuard system. EPS that has been treated with PerformGuard is offered by two manufacturers (AFM Corp. and Rmax); I suggest that you contact them and ask about distributors in West Virginia:
AFM Corporation
24000 West Highway 7
Excelsior, MN 55331
800-255-0176
Fax: 612-474-2074
http://www.r-control.com
Rmax, Inc.
13524 Welch Rd.
Dallas, TX 75244-5219
800-527-0890
972-387-4500
Fax: 972-387-4673
http://www.rmaxinc.com
[email protected]
Try Mid-Atlantic Foam (http://mid-atlanticfoam.com/). They have a facility in Winchester, VA (~4.5 hours away from Charleston). They sell under the R-Control brand and offer the PerformGuard system Martin mentioned above.
