Where can I find solar insolation for windows (tilt=90) for November to April (when solar heat is helpful and when trees are bare)? Ideally considering clouds.
Melville2 | Posted in Expert Exchange Q&A on
[Edit: maybe solved — except for CLOUD EFFECTS (can’t find data / info for my location).  Calculations in comment.]
Latitude: 44 degrees north. (80 west)
Most sites about solar insolation focus on photovoltaics, not windows / vertical surfaces.
Most sites assume a tilt of 0 (horizontal) or a continually optimized tilt. They calculate the daily average by dividing the annual by 365, but solar heat in the summer won’t help me in winter so I need the insolation for … let’s say around 180 days from Nov 1 to April 30.
(The full heating season is longer, but if the outside temp is 3 degrees colder than the desired inside temp, and windows heat my house by 6 degrees, only 3 of those are helpful. Also, I have big trees outside my windows so when there are leaves I get near-zero direct insolation.)
Where can I find solar insolation for windows for November to April (when solar heat is helpful and when trees are bare)? Ideally considering clouds.
  1. LukeInClimateZone7 | | #1
    Hack answer maybe:
    Use pvwatts and just set up a 1kw vertical PV system facing the direction of your windows. Not perfect, but easier than transforming horizontal beam radiation with trig (and then add diffuse with view factor)
  2. Melville2 | | #2
    Thanks.
    Reading the information popup next to the system size, I set the system to 0.16 kw to attempt to approximate 1 square metre. Do you know if I was wrong to do that? Calculations at the end of this comment.
    With tilt 90, azimuth 170, system losses 0, array size 0.16 kw (attempting 1 m2*), I get an average 3.22 kwh/m2/day over the whole year, and 3.45 for november to april.
    I changed system losses to the default 14% and as expected that doesn't affect the insolation calculations.
    I have not been able to find estimates of cloud effects for my location.
    Using 3.45:
    621.6 over 180 days - per sq m
    $0.20 cost of 1 kWh
    $124.32 per year solar $ gains - per metre squared
    15.6 metres squared
    $1,939.39 per year solar $ gains
    Now need to find cloud effects.
    *The default PV system size is 4 kW. For a system with 16% efficient PV modules, this corresponds to an array area of approximately 25 m² (269 ft²)
    Using the rooftop size estimator, the smallest it would let me make was 3 m2: System Capacity: 0.5 kWdc
    4/25 = 0.16. 0.5/3 = 0.16.
    1. LukeInClimateZone7 | | #3
      The PVWatts data should include clouds from TMY3, I think. But don't quote me on that exact data source. I think it depends on your site.
      The national solar radiation database: https://nsrdb.nrel.gov/
      1. Melville2 | | #4
        google's AI reply:
        "Yes, PVWatts uses typical meteorological year (TMY) data, including TMY3 data, to estimate the energy production of photovoltaic (PV) systems"
        So cloud effects are already factored in - good!
        Thanks
  3. big__o | | #5
    Susdesign.com has a window heat gain calculator
    1. Melville2 | | #6
      Thanks. https://susdesign.com/windowheatgain/index.php. It does alas require that I set what percent cloud cover to use for each month, and my previous attempts to find that kind of info lead nowhere. .
