When using a LED conversion kit for a recessed lite, can you fill the can with fiber glass insulation?
![](https://secure.gravatar.com/avatar/a29701480c3cd0aa82db7e479f8d8bbb?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
I have two lights in a vaulted ceiling that leak air like crazy and make it difficult to keep the room warm. If not is there a better way to insulate the lights without replacing them?
I wouldn't stuff with fiberglass, because:
1) Fiberglass doesn't actually do much of anything to stop airflow, and
2) LED lights are most efficient when they are cool, so insulation will degrade their performance.
Instead, I'd caulk between the trim ring of the retrofit unit and the ceiling. Yes, that's more permanent than one would normally use to install a lightbulb, but the LEDs should last 25k to 50k hours. Alternatively, you could use some kind of gasket there.
You may have noticed that Home Depot has high-performance CREE downlight retrofit units for $20 now, which I think is an amazing bargain, especially since they have excellent color (CRI > 90).
LED lights are electronic devices (Light Emitting Diodes) that produce heat and MUST have adequate cooling to prevent damage and maintain life and efficiency. Even though they produce much less waste heat than incandescent lamps, they must still have enough cooling dissipation to keep from failing from high circuitry temperatures. Don't stuff the cans.
