Whats best way to insulate unvented attic room and room without vents
![](https://secure.gravatar.com/avatar/7b418fb3599627f2b13d2ab38a9e6b4a?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
first part.
Im building new house in douglasville georgia i think zone 7. or 3 . i have bonus room above garage with 10 x8 part of the room will be vaulted ceiling , ( rest of the room 16×8 is standard with regular ceiling.) the vaulted ceiling has 2×10 rafter 16″apart 10/12 pitch. the vaulted part of the ceiling i plan to not vent and do closed cell spray foam, is that best way to go? i dont want condensation and i dont want to add on to reduce the ceiling height, garage below will not be heated or cooled.
second part.
this house is 2 story so one room on the first floor has a lvl beam holding second floor wall. this room ceiling is 1/2 under the second floor and 1/2 shares the front porch roof with 4/12 pitch and a metal roof . how do i insulate this with no way of venting it beacause the second floor wall is right above it, also there is not much space in the ceiling for blow-in insulation. should i block off the porch part of the ceiling away from the room and just do spray foam? closed or open cell?
Hi tolydj,
First, if you are in Georgia, you are definitely not in zone 7. You are in either zone 2 or 3 depending on where Douglasville is located in the state. Here's a map to help you figure that out: http://www.greenbuildingadvisor.com/article/climate-zone-map-including-canada.
You can certainly go with unvented assemblies in these two roofs, just make sure that you are hitting the appropriate R-values with the right types of insulation. This article has all of the info you will need: http://www.greenbuildingadvisor.com/article/how-to-build-an-insulated-cathedral-ceiling
