What’s a good way to detail an exterior corner with rigid foam?
![](https://secure.gravatar.com/avatar/b2f3b4dc58323729b392a6a6a0391efb?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
I’m planning on improving an existing 2×4 wall by installing 2 layers of 2″ polyiso or 4-1/2″ nail-base panels. I’ve found good pointers on this site for most of the details, but am still unsure about how to handle the exterior corners so that the rain-screen strips and siding corner-boards have something solid to attach to. The corner-boards will likely only be a few inches wide, so not wide enough to catch any framing. I’m assuming a butt-corner with nail-base, so there would be OSB on only one side of the corner. How do you do this without creating a thermal bridge?
Hope that makes sense.
Any suggestions?
Cheers,
Andrew…
Andrew,
One technique we've used is to trim screw the edges of 2 sections of Advantech together to form a furring "corner board" (or other weather durable sheet good wide enough to reach from corner back far enough for a structural screw to be able to attach firmly to a corner stud).
Your trim boards and siding won't be thoroughly back vented at the corner, but you'll have good firm nailing attachment and still keep a clear foam corner without a thermal bridge.
Thanks for the response Jesse. I was thinking of something similar. I'm not sure that the lack of lack of venting near the corner is that big of a deal, but I'm always curious about best practices.
Cheers.
