What type of insulation and how much insulation should I use between ceiling joists in garage?
![](https://secure.gravatar.com/avatar/d2289cca06d79bac3f95a6afbc337081?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fj.png&r=g)
I live in zone 5 in northern New Mexico and live in an apartment above a 3 bay garage. The ceiling joists in the garage are 2×12 on 12″ c/c. The only heat source for the upstairs is from a small wood stove. I need to insulate the ceiling of the garage below. The garage walls have no insulation. What type of insulation and how much insulation should I use between ceiling joists in garage? Also I would need to insulate the rim joists.
James,
According to the 2009 Intenational Residential Code, the minimum R-value for floors in Climate Zone 5 is R-30.
Here's an article that tells you everything you need to know about insulating the ceiling of a garage (in other words, the floor of an apartment over a garage): How to Insulate a Cold Floor
Thanks for the information. I can work from the pdf file you sent. It seems that I need to learn to spray foam insulation.
James,
It's best to leave the installation of spray foam to a trained contractor. It usually isn't a do-it-yourself job.
With 2x12 running 12" o.c., with blocking and rim joists you're looking at something like a 20% framing faction, so even a full cavity fill of cellulose won't quite hit the same whole-assembly R of R30 in 16" o.c. joists. The rigid foam below is critical to making it a true high-performance assembly.
Doing a flash-inch of closed cell foam for air-sealing can be a DIY project with a 600 board-foot Tiger-Foam/Fomo-Foam etc kit. Doing a full cavity fill of open cell foam is definitely not DIY territory, and may be cheaper in the end than a flash'n'fill with dense-packed cellulose. (The high expansion of open cell makes for a tighter assembly than you'd get with a flash-inch approach too.)
Okay. Thanks for the heads on on spray foam insulation.
