What to put on top of slab insulation in the bathroom?
![](https://secure.gravatar.com/avatar/752e5fe1f3b477427cdf5df207d2434f?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
I previously asked about insulating my existing slab and am underway with the project; 3/4″ rigid foam, 2 layers of floating plywood with the first 3/4″ and second layer 1/2″. My question is what to do in the bathroom where tile will be the finish floor? Is one layer of 1/2″ durock on top of the insulation adequate? Should I double it and lay the second layer perpendicular attached via backerboard screws? I just want to make sure it’s stable before the tile is laid. Thanks
Matthew,
You need at least two layers under ceramic tile. If you are installing 3/4 inch plywood plus 1/2 inch plywood everywhere else, then you want at least 34 inch plywood and 1/2 inch Durock under the ceramic tile. But you should confirm these details with your tile installer before proceeding.
