What to do with inactive rafter vents ?
![](https://secure.gravatar.com/avatar/359632f053b6e0519f10844beb40f0b9?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fw.png&r=g)
A rafter space has a foam durovent soffit to ridge vent covered w/ 7″ of closed cell spray foam. Near the soffit a hole is cut through the foam & durovent to install a 14″ exhaust duct for a range hood blower. Obviously a gob of warm moist indoor air is pouring in to the durovent and it needs to be closed off.
– Good enough to just seal it near its base? This leaves the question of moisture build up in the inactive durovent space causing the sheathing to rot.
– Or should the entire vent space be filled with foam to prevent as much moist air as possible from hanging out in there?
Other thoughts?
Thanks,
One option that our builder proposed is to put in some 2.5" flex pipe to join the lower rafter vent/soffit vent with the upper rafter vent/ridge vent and so allow for some air flow through the vent to prevent moisture buildup. ??
