What Non-Wicking, Vapor-Permeable Foam or Insulation to Fill a Basement Ceiling Void next to a Below-Grade Exterior Brick Wall
![](https://secure.gravatar.com/avatar/44d3cc170fda97815cdd96ebaa6ffc16?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
I have a very old house with a non-insulated gap in my basement ceiling and an exterior brick wall that is at or below grade, making it prone to dampness. I’ve read that in century-old homes, it’s crucial to allow the bricks to breathe and dry out, so I’m looking for an insulation solution for the joist cavity that touches the exterior wall. I want to avoid trapping moisture or causing it to wick into the joists.
The rest of my basement ceiling is insulated with rockwool batting. Initially, I placed a plastic vapor barrier against the brick in the joist area and put rockwool behind it. However, I removed the plastic barrier to avoid trapping moisture against the brick, which could lead to deterioration. My concern is that if I leave the rockwool bare, it might absorb moisture from the walls and transfer it into the joist bay. Will it just evaporate, or will it cause problems?
What should I put in that joist bay? Is rockwool a good option, or does it have capillary action that could make the wood damp? Should I use something else instead? Any advice on how to approach this would be greatly appreciated!
