What kind of walls for encapsulating pier and beam crawl space?
![](https://secure.gravatar.com/avatar/34d91bcadab564b68cfcfc62abe5f5b6?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
I’m contemplating encapsulating the pier and beam foundation in CZ-2. The existing walls are a stucco skirt, about 1″ thick, relatively smooth.
Is it acceptable to attach the rigid foamboard insulation to the inside of the stucco skirting, or should I install something else?
If I have to remove the stucco skirting and replace, is there a decent / cheaper alternative to 16 x 8 x 8 concrete blocks, like maybe fiber cement panels?
(Note: The depicted pipe is not connected to anything.)
(bump)
First question: Is your house in a flood zone?
Second: Is the goal warmer floors in winter?
I would read the BSC article first.
https://buildingscience.com/documents/building-science-insights-newsletters/bsi-115-crawlspaces-either-or-out
Not in a flood zone. Goal isn't "warmer floors" per se, it's to not lose tons of heat from the living space through the flooring in the winter, and also to prevent pipes from freezing. Deep freezes are becoming more common with climate change.
I'm not a builder, but I can share what I learned and did on our crawlspace. Encapsulation is a difficult job on an existing home. I found smaller tasks addressed some problems.
Regarding heat loss and saving energy, your biggest air sealing and insulation needs are ceilings and attic floor first, walls doors and windows second, then floor and crawlspace third.
I asked about flood zone because our 1930 pier and beam in Houston, also climate zone 2, is likely to take flood water in the crawlspace someday. For us, it would be such a complicated job to retrofit an encapsulation of our shallow crawlspace with the beams and joists are only a few inches above the ground.
I have done smaller steps instead: insulate pipes, poly sheet on the ground. Air sealing floor penetrations around plumbing and drains, will give you a big benefit too. For the arctic blasts, I cover the crawlspace vents and turn off the water at the curb overnight.
If you don't want to build a block wall from the ground up, can you bring down some framing by attaching to the perimeter beams or band joists?
Michael,
Can you confirm what I think the photo shows: Stucco on lath supported by rebar posts with no framing or sheathing?
