What is the recommended thickness of a vapor barrier under a 18″ raised house in southern Miss.?
![](https://secure.gravatar.com/avatar/42f6a2c6ae5594a365a371e92cfa00ce?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
myragold
What is the reccomended thickness of a vapor barrier under a 18 inch raised house in southern Mississipi?
You mean the floor joists raised 18" off the ground? On a concrete perimeter foundation? On piers? Is there framing or skirting around the base?
Margaret,
Assuming that you want to cover dirt under a house on piers, you should use polyethylene that is at least 6 mils thick. A thicker ground cover will be more durable than a thinner one.
Hold the polyethylene in place with bricks, stones, or a layer of sand. Be sure to install skirting to keep out cats and raccoons.
