What is the proper way to seal a “B” vent in a attic floor?
![](https://secure.gravatar.com/avatar/f7a7b318ed14d31a1aa02c2ef008f274?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fd.png&r=g)
The “B” vent is a 6” heater flue that services the gas foced hot air furnace in the basemet that is 80% efficent. The top of the chase is wide open in the attic. Can I seal the top of the chase with metal flashing and fire caulk? Will this create a fire hazard? I am in the Philadelphia area.
In my opinion you should only use parts and installation methods from the manufacturer of the vent pipe. If you call them, the tech support/product engineering people can usually help.
