What is the most suitable heating system for a 600-square-foot unit in California?
![](https://secure.gravatar.com/avatar/aa99ff3d0e49b3fcd03ed16e16e1f644?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
Dear Mr. Sir,
I am going to convert a 600 sft structure (used to be a detached garage and extension) into a two bedrooms dwelling. Current, there is a bathroom existed and laundry facilities with gas and electricity within structure.
The dwelling is located in San Francisco – Bay area where it has a mild winter (temperature rages from 40 – 65 F).
I’d like to get an advise on the heating system as to what is the most efficient and suitable heating system for a small 600sft space considering the system installation, cost of energy usage and maintenance.
Many thanks in advance!
Red
Red,
It's probable that a ductless or ducted minisplit system (a type of air-source heat pump) would make the most sense, but it's really impossible to provide advice without a lot more information (a floor plan, a description of the building's insulation levels, more information on windows, and -- ideally -- a heating and cooling load calculation).
It sounds as if you may need to consult an architect, mechanical engineer, or experienced HVAC contractor.
A half-ton MItsubishi FH06NA would pretty much cover it, unless you build it out in an EXTREMELY sub-code manner.
Panel radiators or baseboards operating on a condensing hot water heater could cover it if it's a heating-only situation. Cost of operation would be comparable to an FH06, but the carbon footprint is much higher.
