What is the layering sequence when installing a slab on grade?
![](https://secure.gravatar.com/avatar/1e849d666eb1e98ff2c4961340eccb30?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fr.png&r=g)
architect55
| Posted in Energy Efficiency and Durability on
Moisture barrier, rigid insulation?
Robert,
From the bottom up, here’s how the layers should go: Crushed stone; rigid foam; polyethylene; concrete.
If you want to learn more, see Polyethylene Under Concrete Slabs.
