What is the greenest option for adding loft insulation?
![](https://secure.gravatar.com/avatar/6821ce57d656280d22c894c0fad24265?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fm.png&r=g)
On our EPC they recommend adding additional loft insulation. There is currently a layer of blanket insulation between the joints.
What is the greenest/best option for adding another layer?
Cellulose.
+1 for cellulose. It's greenest, cheapest, and usually performs the best too. It's also less irritating than fiberglass. What's not to like? :-) You can blow a layer right over whatever you have now and not worry about it. The only thing to check is to be sure you don't block any soffit vents.
