What is the best heating and cooling plan for renovating an old building into apartments?
![](https://secure.gravatar.com/avatar/c9cdd0731b0c5e71682f4237a31e18a8?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
We currently have central forced air that has the ductwork going through the cold attic, and the suspended ceiling. I would like to tear out the suspended ceiling and put up drywall over the old broken lathe and plaster.
Should I run new duct work under the floor to floor registers (we have room for this since there is space above the ground floor’s suspended ceiling).
Or should I install electric baseboard heat, and a mini split A/C unit.
Another option is to run Pex tubing up from an existing gas boiler in the basement and add old cast iron radiators. But then we would still need an A/C unit for each apartment.
This is a 1930’s brick building located in zone 5A or Southeast Iowa.
Aaron,
You've got a big basket of apples and oranges there, don't you?
These are very basic questions. Here's my advice:
1. First, choose a fuel. Electric baseboard heat is much more expensive than most other options. Does your building have access to natural gas?
2. After you have chosen a fuel, talk to a mechanical engineer you trust. If you really have no idea whether you prefer electric baseboard heat, a boiler, a furnace, or ductless minisplits, you need to sit down with a patient expert and have a long conversation.
3. Before you sit down with an engineer, you might want to read these articles from the GBA Encyclopedia:
Heating Options
Heat Pumps
Ductless Minisplit Heat Pumps
Boilers
Furnaces
Forced Air HVAC Systems
Hydronic Systems
Space Heaters
