Waterproofing Membrane for CMU
![](https://secure.gravatar.com/avatar/e646f484e1d50bde9713281b5aa12268?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
Hey everyone,
I’ve excavated the foundation of our home in southern Ontario and had the compromised foundation fixed. Next step is a new weeping tile and waterproofing. My question is what type of waterproofing membrane will work best in this situation. The CMU below grade is most from the 1950s and is flat on the outside but above grade it has a textured surface. Also on the corners there are some half blocks in which there is a hollow facing the exterior. What do you all suggest for waterproofing? My gut says a peel and stick likely won’t adhere well to the textured block but this is a new realm for me. Any insight or product suggestion would be super helpful! Remember I’m in Canada so hopefully we can find most products here. I’ve attached a few photos so you can see the situation.
Hi Adam,
A recent article was published on this topic you might find helpful:
https://www.greenbuildingadvisor.com/article/dampproofing-and-waterproofing-for-foundation-walls
Others may have specific product recommendations.
Hi Adam,
I have heard one builder with a similar situation recommend Sika Waterproofing Systems. His house has weathered a major hurricane since he installed it, and he says there have been no leaks.
Hi Adam,
You'll have a hard time finding sika products in non commercial settings. Tremco or Henry products are easier to get from construction distributors around here in Toronto and I'll assume wherever else you in Ontario. I've used CDS to get my waterproofing stuff in the past but you'll have to create a business account. (https://cdsco.net/) otherwise homedepot has some consumer grade stuff.
I suggest you fill the half blocks with mortar, mostly to give a surface for the membrane.
Do a roll on liquid membrane as per the specs (since it's block I would use a mesh for ease of mind, but that's me). You don't need to waterproof the above grade bricks.
Then do a drainage layer (dimple sheeting) remember to point the dimples towards the wall. This reduces the hydrostatic pressure against the membrane and let's water drip down to the weeping system. I believe this is key for longevity.
Backfill with the dirt you have or gravel for better drainage.
Jamie
