waterproof membrane on icf walls
jlar2022
| Posted in Expert Exchange Q&A on
I intend to use ICF foundation wall. What is good membrane on the eps insulation?
You can fill the gaps between the ICF blocks with sealant and roll on a membrane. (Best to amek sure they're compatible)
Or use a blueskin style adhesive sheet membrane.
Jamie
We used Soprema in our build. Worked out well.
