Water tank insulation
![](https://secure.gravatar.com/avatar/2d79c1b16f7c10cbb3742c7ca5059198?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fo.png&r=g)
oldmanonporch
| Posted in Green Products and Materials on
I have 2500 gallon water protank, 9 foot high 8 foot wide 24 foot round above ground , what insulation can i use to cover the tank.
Old Man,
I went to the Protank web site to find an image. Does your tank look like the image below? If so, the only type of insulation I would advise is the type of dense roofing foam available from some spray-foam contractors. You want roofing foam, plus the special coating (paint) used to protect roofing foam from UV light.
