Water heater is on vacation mode, and water is 135 degrees
The water heater was replaced a few years ago. Gas Whirlpool model NU30T61-303.
The temperature is always set on vacation mode but still the water is 135 degrees.
Is there a reset button that needs to be pressed? Or…….?
Error above. Water temp remains around 135 degrees not 123
GBA isn't really set up to answer product specific questions. You should contact the Whirlpool® Residential Technical Assistance Hotline at 1-877-817-6750.
Ch Kirla,
It might be a defective aquastat. In any case, you'll have to call a plumber for a service call.
