Choosing Sheathing
![](https://secure.gravatar.com/avatar/19fcc04b407ca3f4f3503346555f3331?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fc.png&r=g)
I am in the beginning phases of a small addition to our early 1900’s home in zone 4a non-coastal Maryland. With this addition, I am planning to add exterior insulation to the existing structure and new siding. The existing interior walls are a mix of plaster and drywall, 2×4 dimensional studs (balloon frame), no insulation, 1×6 dutch lap siding, tar paper, fiber cement shingle siding. What I am considering is removing and properly disposing of the existing siding shingles, adding blown in cellulose to the stud cavities, installing new exterior sheathing over the original wood dutch lap, a wrb, adding 2” roxul comfortboard 80, ventilated rainscreen, Boral true exterior siding. My questions are:
1. For sheathing options, would I get better or more preferable performance from plywood with taped seams and a wrb, or zip with taped seams?
2. If plywood with taped seams is best, should I consider a higher performance vapor open wrb like Deltavent or Blueskin or is this overkill?
Thanks in advance for your input
eng251ine,
My own preference would be to go with plywood and a sheet WRB. It makes the flashing a lot more forgiving relying on laps and not tape.
While I see the benefits of expensive interior variable-perm membranes, I'm not convinced the high performance WRBs add much that a good conventional one like Tyvek Commercial doesn't give you.
