Landscape Fabric Over Wet Substrate
![](https://secure.gravatar.com/avatar/675d73deb42355324e6bc666f6116ded?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Fw.png&r=g)
Working on the gravel driveway and it just rained all over my nicely leveled ground.
Should the dirt be dry before I put the fabric down and cover it with 10 inch base material?
Thoughts.
Thanks
Any thoughts on this?
idahobuild,
I don't see any reason to wait until it is dry.
As you drive/pack over your gravel fill, water will likely percolate up through the fabric into your base. Not a problem.
If your native soil is soft when wet, I would make some effort not to drive too much over thin gravel-- thicker gravel will distribute the load and prevent the fabric from being trenched down into a muck hole. (a tracked machine is likely not a concern-- a loaded dump truck has a lot of psi though).
Thanks All.
