Vertical exterior trim on outside corners on homes with exterior rigid foam
![](https://images.greenbuildingadvisor.com/app/uploads/2018/08/08123500/martin-holladay.jpg)
For an article on installing exterior corner boards on homes with exterior rigid foam, I’m soliciting photos or architectural details showing wide furring strips or other techniques to make sure that there is solid backing to allow the attachment of corner boards or siding at outside corners.
You can post your images here, or email them to me:
martin [at] greenbuildingadvisor [dot] com
Thanks very much to everyone in the GBA community for all your contributions!
Here is a corner that shows 3/4" OSB about eight inches wide all the way up the corner. Hope this works.
This is a 24" deep inside corner under the front porch. We used a 24" sheet there instead of cutting two smaller strips.
Joe,
Thanks for the photos! I appreciate it.
