Red-Pen Test for Air Barrier
![](https://secure.gravatar.com/avatar/0729f81db0ceee0fb936f9be2b506e6b?s=52&d=https%3A%2F%2Fimages.greenbuildingadvisor.com%2Fapp%2Favatars%2F200x200%2Ft.png&r=g)
Hi,
I’m building a single family residence in WA state (zone 4 Marine).
Floor:
Stegohome vapor barrier under 2×4 sleepers and T&G subfloor. This is over a poorly finished concrete slab that has R10 XPS underneath. I will tape perimeter of plastic to 2×6 walls (might use siga’s rissan tape) and then use Prosoco on the exterior side of the wall sealing the bottom of the plywood to CMU blocks.
**Should I add additional insulation between 2×4 flooring joists?
Wall assembly from exterior:
Hardieplank, rain screen [non-PT 3/4″ utility lumber], 2″ Roxul Comfortboard 80, Prosoco Cat 5 (my air barrier with joint and seam for fenestrations), 15/32 CDX plywood, 2×6 stud walls, cavity filled with Roxul R23 Comfortbatt, Drywall, latex paint (my class iii vapor retarder).
Wall to Roof connection:
Tape prosoco covered wall to XPS
Roof assembly: (I have 32′ spanning room-in-attic trusses and I want R49)
Shingle, 30# felt, 19/32 CDX plywood, roof trusses in cavity [1.5″ air space from eave to ridge, unfaced R38 insulation batt to fill cavity, staggered 2.5″ of XPS inside ceiling joists with “Big Gap” spray foamed edges, 3/4 furring strips, drywall, latex paint.
Do you see any causes for concern?
Is there a better way to air seal the roof? Also concerned with wall to roof transition. I really wanted to build Risinger’s “monopoly house” but I’d need to re-engineer the trusses. The trusses also prevent me from adding exterior insulation.
Tried to make this post brief :/
Please let me know if you need any additional info.
Thanks,
Tim
Tim,
I'll give your post a bump.
Thank you
** In your climate zone, adding insulation between the 2x4 floor joists is probably unnecessary, but would nearly double the effective floor insulation. And, it won't hurt anything. Pretty cheap upgrade.
