Hi,
I am looking for some opinion from everyone on GBA on which ventilation setup I should lean towards. I know there are different views and approach but I am open to all of them at the moment.
I will be using a Mitsubishi Zuba Central which is a ducted heat/cooling heat pump system with a Vanee G2400E ECM (ERV) ventilation system.
Our initial plan was for a dedicated ducted ERV system but the mechanical contractor advised us it would cost more for the additional ducts and we would also need to install a post-heater just downstream from the ERV to increase the fresh temperature heading to the rooms.
They suggested a hybrid approach, use the forced-air heating duct system to supply the fresh air which would eliminate the need for a post-heater since the fresh air would be mixed with the recirculating air. The exhaust would be taken from the bathrooms using a dedicated duct system.
– Is it worth the additional thousands of dollars for a dedicated ducted ventilation system?
– If I go with the hybrid system proposed, would the ERV unit have sufficient power to circulate fresh air on its own when the heating/cooling system is not required or will the furnace blower need to be synchronized with the ERV unit?
Thank you,
Arnold
The independent, ducted system is the gold standard. You don't need a downstream heater. The standard recommendation is to position the vents such that they're not blowing directly onto people. I've stood right underneath a vent while it's running at maximum and I couldn't feel it.
Hi Trevor,
Do you feel the independent, fully ducted system significantly better to warrant the high price tag?
Thanks,
Arnold
